File upload at a glance
14.Nov.06 19:30
24472
Georg Richter (D)
Articles: 909
Count of Thanks: 59
Georg Richter
Dear all,
Here first how to treat pictures with a free picture software program, IRFANVIEW. At least the instruction is worth while. Use big sized pictures with a big object in them.
Upload to Content File
Format
Color
B/W
2-6
grey-
scales
B/W
16+
grey-
scales
Prefered
file size kB
Max.
file size kB
Width,
pixels
(max.)
Height,
pixels
(max.)
Models
Pictures
.JPG
.GIF
.PNG
 yes  no  yes 300-600 <= 600
1400
2100
  Schematics
[4]
 .PNG
 .GIF
 .PDF
 [4.1]
 yes
no
600
5000
Scan 300 DPI
5000
Makers
[5]
Pictures  .JPG  yes  yes  yes 300-600 <= 600 1400 2100
Tubes Pictures  .JPG  yes  no  yes   600 1400 2100
.GIF
 no  yes  no     150 fix 250
.GIF
 no  yes  no  as low as
possible
  640   700
  Charac-
teristic
.PNG
.GIF
 no  yes  no as low as
possible
Scan 300 DPI
Animated GIF
150 fix!
Forum Pictures
 [2]
.JPG
.GIF
 yes  yes  yes   <= 120 ! 600
  Spread-
sheets
[3]
any Text,
small
pictures
 yes
 yes  yes
    600
  Attach-
ments
 .JPG
.GIF
.PDF
 yes
 yes
 yes
as low as
possible
<= 200 !
  Articles:
Editor-
Instructions
Your contribution is welcome. We are polite and respect each other, and avoid bad words. For problems we turn to an administrator or to the Mediator.
Private Pass-
port
.JPG
.GIF
.PNG
yes no yes as low as
possible
50 !
150 fix 200 !
.GIF
.PNG
possible
600
1400 2100
FILE UPLOAD SUMMARY
Please click on the bold underlined Links for additional information.
[1] Pictures of a tube (valve) should display the tube (valve) only. Please cut your pictures accordingly.
[2] Pictures for the Forum should be of reasonable size before upload, not shrinked after upload. Another "how to" is here. You can add high-res pictures and schematics using the  Attachement(s)  button beside of   Submit  .
[3] Even if you have preset the table width to 600 pixels you have to check wether the size may have increased by adding some entries. Enabling multiple lines for a cell will help you.
[4] Pixels at 300 dpi. A circuit diagram must be (rotated if necessary) in portrait mode, top to the left, the dimensions are rule. PDF is not allowed. A must to read is the "how to" here.
[4.1] For modern schematics printed in colors you find an orientation here. A special instruction is not yet available. If in doubt consult the schematic administrator.
[5] "Makers" is synonym for manufacturers and brands.
The above data are collected from all the   i   I have found.
Please click on  [ Mail to the author ] in case of any complaint or suggestion.
Kind Regards
Georg
