Philips schematic capacitor notation
? Philips schematic capacitor notation
Greetings to all,
Could one of you fellow members please explain how capacitors are labeled on European schematic diagrams ?
As an example, I am currently using a diagram for a Philips BX250 B 00. Some capacitor's values are marked as "8E2", "2K2" or "47K" - I am at a loss to understand the markings. (I'm doing much better with resistors though....I understand their markings). Other caps marked "400" or "82", for example, are obviously noted in picofarads.......likewise, a cap marked 4uf is quite obvious also.
Is there perhaps an online chart of some sort available that would explain the system ?
Thank you in advance
Dennis Wesserling - USA
added link
Philips notation of capacitors and resistors
Capacitors:
1F =1 Farad 1mF=1 Millifarad 1µF=1 Microfarad 1nF=1 Nanofarad 1pF=1 Picofarad 1F=103mF=106µF=109nF=1012pF
Examples as seen on Philips and other European schematics:
8E2 = 8p2 = 8.2pF 4k7 = 4n7 = 4.7nF = 4700pF 100 = 100µ = 100µF = 100 000 000 pF (electrolytic capacitors) 100 = 100p = 100pF (ceramic, mica and variable capacitors)
Resistors:
1Ω =1 Ohm 1kΩ =1 Kiloohm 1MΩ =1 Megaohm 1GΩ =1 Gigaohm 1 Ohm = 10-3kΩ = 10-6MΩ; = 10-9GΩ
100 = 100Ω 4k7 = 4.7k = 4.7kΩ = 4700Ω 8M2 = 8.2M = 8.2MΩ = 8 200 000Ω
More information about codes:
Colorcodes of Beyschlag resistors
RMA codes (in german language)
Philips capacitor
The letter stands in the place of the comma.
8E2 = 8,2pF
400 = 400pF
2K2 = 2200pF
47K = 47000pF etc. (K = Kilo/1000)
But where is the circuit and the model that you mention?
Please place the model in RM.org.
Regards WB.
Model is entered.
Thank you, to all who responded, for your input.
Model Philips BX250B(00) has been entered into the site's archives.
added link
