Wrong Model Upload
Wrong Model Upload
I discovered that I uploaded photos of Model 3A5 into Model 5A5 and I don't know how to correct it. Again the photos that I uploaded as 5A5 are actually model 3A5. Hopefully someone can correct my mistake.
Wrong Model Upload
Hi James,
you forgot to tell us the Brand of 5A5 and 3A5. I find the models by using your profile. It is General Television and Radio Corp.; Chicago, IL. short “genera-tv“.
How can you identify the difference of both models?
The 5 Images have been blocked. Please upload the pictures with correct file name to correct model and include a photo showing the type.
Heribert
Wrong Model Upload
Sorry I forgot the brand need to be more careful and yes it is General Television. The only difference visually that I can find between the two is the dial/tuner faceplate. The 3A5 only has the upper portion with kilocycles. The 5A5 has meters too below and hence a two sided pointer.
I will upload my photos again to the General Television Model 3A5 (1946) when I get a chance.
Thanks
Jim Hochstetler
P.S. I also believe that one of the tubes is listed incorrectly. It shows a 12SG7 and I believe it should be a 12SK7. Please double check that I'm new at this.
