elektronik: EMG-1341 (EMG1341); Orivohm
This article refers to the model: Orivohm 1341 (EMG, Orion-EMG, Elektronikus Mérökészülélek Gyára; Budapest)
02.Aug.07 20:53
2251
Orivohm is a very handy and durable VTVM fro everyday use. Simple, reliable.
Modes: AC Voltage 0.1 - 300 V
Frequency range: 30 Hz - 25 MHz
Input impedance: 300 kOhm || 20 pF
Accuracy : +/- 5 %
Ranges: 3 - 10 - 30 - 100 - 300 V
DC Voltage 0.1 - 1000 V
Input resistance: 15 MOhm
Accuracy : +/- 3 %
Ranges: 3 - 10 - 30 - 100 - 300 - 1000 V
DC zero indicator: In every DC ranges
Accuracy: +/- 1.5 %
Ohmmeter: 0.2 Ohm - 1000 MOhm
Supply voltage: 3 V
Mid-scale points: 1 - 10 - 100 Ohms
10k - 100k - 1M Ohms
Accuracy: Between 0.1k - 100k +/- 5 %
100k - 10M +/- 10 %
otherwise +/- 20 %
Warning!!! In the lower ranges ( x1 Ohm, x10 Ohm the measuring current can be up to 300 mA!!!
That means that tose ranges are not suitable to check semiconductors!!!
Accuracy : +/- 5 %
Accuracy : +/- 3 %
Accuracy: +/- 1.5 %
Supply voltage: 3 V
100k - 10M +/- 10 %
otherwise +/- 20 %
