hallock-wa: Instructions: Halowat TR-5 Version 2
This article refers to the model: Halowat TR5 Version 2 (Hallock & Watson Radio Corp.; Portland, Oregon (Halowat))
08.Jan.15 22:53
1356
-----HALOWAT-----
Instructions
Type “TR-5” receiver (Version 2)
CAUTION: CONNECT ALL BATTERY WIRES TO RECEIVER BEFORE CONNECTING BATTERIES THEMSELVES. THEN CHECK THEM AGAIN TO BE SURE YOU ARE RIGHT BEFORE CONNECTING TO BATTERY POSTS.
The aerial should be around 75 feet long in the horizontal part and as high as possible. The ground should be as short, direct and low resistance as can be made. Fasten firmly to the water pipe AS NEAR AS POSSIBLE TO WHERE IT ENTERS THE SOIL. USE COPPER WIRE.
Use four 201-A, (301-A) or any good independent tube with the same characteristics. THE “SECOND AUDIO” TUBE (REAR LEFT SOCKET) MUST BE A UX 112. The “A” battery is the standard six volt storage and the “B” battery must be 135 volts tapped off at 45 and 90 as the binding post show. The “C” battery should be a single 4 ½ volt block.
With battery connections made as indicated on binding posts and loudspeaker connected to proper posts turn all 3 dials to approximately 48, put 3-point switch on “M” and turn volume rheostat about three-quarters on. In this condition slowly swing No. 1 dial between about 40 and 50 until maximum signal from KGO, Oakland is obtained. When you have determined position for No. 1 dial, vary No. 2 and No. 3 just slightly and then adjust signal intensity with the volume rheostat. It will be found that No. 2 and No. 3 dials operate practically together throughout the entire wave length, No. 1 varying somewhat with the antenna.
Generally speaking the 3-point switch is left on “S” for stations up to about 35° on the dials on “M” from there to about 60° and on “L” for the balance, that is 60 to 100°. The volume and quality are controlled by the volume rheostat entirely which handles the two radio frequency tubes. The detector and 2 audio filaments are handled by a fixed resistance in the base of the receiver, which is set for 2 201As and 1 UX-112.
The proper setting of the “volume” rheostat is always the point just below where the tubes will go into oscillation. This will vary somewhat, depending on whether the switch is on “S” “M” or “L,” and a little practice will bring the desired results.
NOTE: The wording of this document was taken, verbatim, from the "INSTRUCTION CARD" on the lid of the Halowat TR-5 Version 2, 1926.
Bruce Morgenstern
