网上收音机博物馆
网上收音机博物馆
14.May.10 18:01
1
Officer
Articles: 5751
Count of Thanks: 44
网上收音机博物馆 Just a first post to test if one can begin the title and the text with Chinese.
This will be deleted after the use as test is not necessary anymore.
Every member can write in Chinese to this board, but answering is only possible by the moderators which can be seen in the upper part.
Sequence of posts/threads is alphabetical because this will be the board for FAQ and Instructions.
If everything workks fine we then will be able to add a board which functions by sequence of date and if needed a board only members can see.
Use the radiobutton for question only if you are sure to get an answer within 6 days - otherwise it will fall back to the board "Talk".
Please select "Other languages" as language. That is very essential - and select also "Other languages" as your selected forum language - if you want only ot see Chinese - but preferable "Other" and English.
This is a second post
14.May.10 18:02
1 from 16617
Officer
Articles: 5751
Count of Thanks: 70
Since I'm a moderator I can naturally also add an other post.
