4-65A/8165 Tube tester data.
? 4-65A/8165 Tube tester data.
Count of Thanks: 9
I'm looking for set up instructions to test a 4-65a/8165 tube on a US military TV-2 tester. Any help is appreciated. Thanks, Sean.
Better to have this on the model page
Dear Sean
You are a member since two weeks only and there is surely a lot to learn about Radiomuseum.org.
You have started this post on a tube forum page and I have now moved it to one of the models "Test Set, Electron Tube TV-2 ...", hoping that it matches yours. We show several models.
Only a fraction of US members use the forum (I guess). Therefore it would be good for you to click the model, go over "My Model" (mouse over) and then click "I need this schematic". This will stay until some schematics are uploaded to the model. You have a good chance that the uploader sees your article which is now sticky to the model.
In any case it is depending on the activity of US members here since this tester is from the USA and not much known here. Maybe you have an other version - which is not yet covered by a model page. Can you then use the link "Create new model" to enter the data - and after acceptance some pictures?
Activity is the way to serve colleages - and colleages serve you!
Then you are also part of the most complete reference work in the world for radios and retated.
