6BZ6 (6BZ6)
6BZ6 (6BZ6)
14.May.12 11:00
19
Bart Slager (F)
Articles: 9
Count of Thanks: 36
Proper procedure
14.May.12 14:23
19 from 5940
Emilio Ciardiello (I)
Articles: 527
Count of Thanks: 15
Emilio Ciardiello
Dear Bart,
you should ask a tube administrator for adding a new tube code, giving him as many datails as you can: brand, data and source, source of the equivalence and so on.
Emilio
Same as 6AN5WA
14.May.12 20:40
37 from 5940
Articles: 527
Count of Thanks: 23
Emilio Ciardiello
Dear Bart,
I checked this code and it is just an internal part number, probably assigned by the designer of the AN/GRC-106. Look at TM-11-5820-520-34P-1, page 3, for the definition of the field 'Part Number'.
Usually internal codes refer to components that can be supplied by different manufacturers, even with different ordering codes, all approved for use in a given set. In this case the code can be referred to maybe in the descriptive field of the set, but it is not a new tube code.
Emilio
