6J5 chinese power tube pin assignment
? 6J5 chinese power tube pin assignment
16.Nov.20 12:27
28
Giuseppe Feniello (I)
Articles: 91
Count of Thanks: 5
Hello radiofriends,
recently I have bought a tube preamplifier that uses two 6J5 tube ( chinese version with 7 pins ).
Please have someone the pin configuration for this tube? many thanks in advance.
16.Nov.20 14:56
28 from 5153
Officer
Articles: 1735
Count of Thanks: 14
Hello Giuseppe,
please show some good detailed pictures of the 7-pin Chinese 6J5 here in the forum and upload them also to the tube page. Maybe the pin-out can be determined by examination the pics.
Furthermore, the preamplifier should be added as a new model suggestion.
Until now, the only model in RMorg using this tube, is a Chinese console Peony 牡丹 1201. Real pictures are stil missing there.
According to the schematic, the Chinese 6J5 is a kind of beam power tube. It's not a triode, in contrast to all other 6J5 variants.
Thanks for your assistance in this matter.
Best regards
Bernhard
16.Nov.20 15:35
33 from 5153
Articles: 91
Count of Thanks: 7
Hello Bernhard,
thanks for your reply, till now I have found the pins 3 and 4 are the heater filament, and think the pins are the same of the chinese 6J1 pentode, but obviously I'm not sure!
The heater current is about 430mA @ 6,3Vcc
this preamp is a kit, not a complete model.....
I have attached a photo of this tube
best regards...
G.
17.Nov.20 08:25
107 from 5153
Articles: 1801
Count of Thanks: 14
Hello,
the 6J5_China is obviously the Chinese version of the Russian 6Ж5П, which in turn is the Russian version of the 6AH6.
It uses a beam structure, but it's no power output tube, - which wouldn't make sense in a preamplifier.
Best Regards,
Jacob
17.Nov.20 09:22
114 from 5153
Articles: 91
Count of Thanks: 6
Thanks  Jacob for your notes !
so the pin assignment are like the russian version  .....in my preamp, this tube is used as a triode with a connection between pin 5 and 6.
However the chinese schematic uses it as a power output tube in the AF final stage.....
now I know all the pins functions....thanks again.
best regards.
G.
17.Nov.20 10:03
125 from 5153
Articles: 1801
Count of Thanks: 11
The datasheet of the equivalent 6AH6 tells about a maximum plate dissipation of 3.2 W, a nominal operating plate current of 10 mA at 300 V, which may be sufficient for a modest output power, but there is nothing told about this use.
B R, Jacob
17.Nov.20 11:39
144 from 5153
Articles: 91
Count of Thanks: 9
Thanks Jacob,
the the pin assignment picture in the 6J5_China page is not the right one, in reality there is not an internal connection between pin 2 and pin 7.....I have uploaded a new pin assignment picture.
B R.....
G.
17.Nov.20 17:56
177 from 5153
Articles: 1801
Count of Thanks: 6
Unfortunately a wrong base diagram was shown at the original 6AH6 page, which I've copied unaware to the 6J5_China page. Now I've replaced it by the correct one everywhere.
BR Jacob
18.Nov.20 10:52
224 from 5153
Articles: 91
Count of Thanks: 16
