A410_Philips (A410_Philips)
Hallo zusammen,
kann mir jemand erklären, warum Valvo eine A410 mit Werten, die von denen der Philips-A410 abweichen, hergestellt hat? Oder sind unsere technischen Daten bei der Valvo inkorrekt und es handelt sich doch um die selbe Röhre?
Ich will da keine Baustelle aufmachen, aber es würde mich schon interessieren, ob es auch noch ähnliche Fälle gegeben hat.
Danke, und viele Grüße
Mark Hippenstiel
A410
Dear Mark,
I do not know for certain in this case, but one quite probable reason is that they were named independently. There was no agreement between manufacturers in 1925.
The numbers chosen were the obvious ones 410 = 4V 0.10A (406 0.060A).
Then there was the pressure to reduce battery consumption so a valve would be announced as 0.06A then a little later a small ca (approximately) can be seen in the leaflets!
Also even when a type was "copied" production possibly led to a slightly different product!
There are many cases of tubes being named the same but with completely different function - not only a difference in characteristics. For example DE1 and DE2 appear as both triodes and rectifiers.
Perhaps someone knows for certain the A410 story, but my guess is simultaneous naming.
Kind regards,
Roy
Mr. Hupse wrote:
Dear John, and dear Roy,
thanks for the further insight. I recollected that the merger (or take-over) between Philips and C.H.F. Müller had already taken place when those two types were released.
But this would only take place ca. 2 years later (1927) - and a Philips prospectus of 1927 calls the A410 an "old" tube already, now (application-wise) superseeded by A442 and A453, but still on stock or production.
I would have guessed that even back then companies would have looked over the fence (of their home market), especially in the case of Philips which employed a very expansive strategy already from the beginning.
But Roy's probably right, since both types were released in 1925, only a year (or less) after the founding of Valvo.
Regards,
Mark
