ABC1_7pin (ABC1_7pin)
Hi, Would anyone have data for the ABC1 tube with the british 7 pin base.
ABC1
Hi,
it's hard to imagine, that the data for the ABC1_7pin may differ in any way to the normal ABC1, with exception of the base diagram.
The base diagram for the ABC1_7pin is most likely the same as for the Mullard TDD4, whereas the data for the TDD4 are close to the ABC1.
Regards, Jacob
ABC1
Thanks.. I mainly wanted to base connections... so the tip about it being similiar to the TDD4 may be useful.. I'll compare and see if I can work suitable settings for an AVO model CT160 tube tester.
