agabaltic: 1641; Missing Station dial/scale: Schale gesucht
This article refers to the model: 1641 (AGA and Aga-Baltic Radio AB; Sweden)
10.Apr.06 17:35
![Jörgen Svensson](https://www.radiomuseum.org/image.cfm?image=s_svensson_jorgen_2004_2.jpg&width=120&height=140)
Hello!
I have an AGA 1641. And this a very embarassing thing to ask for..
Since this was the first radio I was thinking of cleaning, I made the beginner's MAJOR mistake!
I tried to wipe the dial clean with a moist cloth...
And as YOU all know, and I didn't know, all of the print disappeared.. I shed a few tears, and decided that I wouldn't do any restoration for a while.. ;o)
Well, My question is, with the above mentioned as background: Is there anyone out there, that has the possibility to scan a dial and sell the scanned image to me, so I can make a new one?
I am having thought that I can use a water-decal, you know, they are used on e.g. airplane models, and similar.. You put it in water, and slide in onto the surface, and when dry, it is finished!
I have heard that there are such decal foils available to use with ink-jet printers, and if I could get a scanned image of the dial, I might make a new scale in glass or acrylic plastic..
I think it is best to scan it mirrored, I mean, putting the dial with the text side (inside) downwards, because otherwise there would be a couple of millimetres between the text and the scanner..
Is there anyone that could help me with this?
Thanks for reading this!
Kind regards
/Jörgen Svensson, Sweden
GR: 86kB .GIF replaced by 17kB .JPG
Kind regards
Who can help
09.Dec.07 08:07
I just ran into this - no answer yet.
Who has this set and could take that photo?
Copy within the next time
09.Dec.07 13:32
![Dietmar Rudolph † 6.1.22](https://www.radiomuseum.org/image.cfm?image=Dr_R_2.jpg&width=120&height=140)
Unfortunately, I did not recognize the post in April 2006.
Well I have an AGA 1641 with the curious mixer tube 6SJ8G. Within the next time I will make a copy of the dial glass. But first I have to look for a possibility for A3 scanning at my location.
Kind regards,
Dietmar Rudolph
Kind regards,
Dietmar Rudolph
