AWA Model Numbers - Significance of a suffix
![Brian Wilson](https://www.radiomuseum.org/image.cfm?image=aus_wilson_brian_2006.jpg&width=120&height=140)
I noticed on the site for the AWA 208PY that an AWA 208P that I have just obtained differs in minor ways from the later 208PY. In fact, the suffix indicates a MINOR revision of the circuit/schematic. The order is Original ----- No Suffix. First revision ----- Suffix = "Z". Second revision ------ Suffix = "Y". Third revision ------- Suffix = "X". I have not seen a Suffix "W" but that is not absolute proof of anything. The suffix does not seem to appear in advertising in anything that I have seen between 1956 and 1975. ALSO This "Suffix System" flows on into radios made by AWA for Email Pty Ltd and others. In the period from 1957 to 1975, Westinghouse, Hotpoint, Airzone are all re-branded AWA models. It may that there are others as well where this system was used - particularly for "Store Brand" radios and car radios made by AWA for various car manufacturers and assemblers in Australia.
![Gary Cowans](https://www.radiomuseum.org/image.cfm?image=cowans.jpg&width=120&height=140)
Explanation from John McIlwaine, AWA Historian and long term employee of AWA on the model number suffix revisions;
He states the AWA first model number for say a model is 208 P, (P) being for portable, for modifications to the first model only three engineering changes could be made and the letter suffixes X, first change, Y second change and finally Z were used and added to the original 208P thus 208PX, 208PY and 208PZ
.No more changes could be made to the model after three changes, and a new model number would be required. This system was vital to rationalise service manuals and spare parts ordering in the field.
Brian Wilsons observation is correct:
In this example 805GY is the second change (after Z). In this case the T & R suffix indicate that those versions use a 3-speed automatic changer as opposed to Y & W versions single speed changer. The differences between the T & R version could be simply just a different brand or type of record changer. Also some suffixes such as S or U may not have been used in this system. In the case of the 805G a X version is currently not known.
