blaupunkt: Serie T ab 580001; Hamburg ATR Alltransistor
15.Jan.13 19:07
2041
Officer
Articles: 5751
Count of Thanks: 11
From guest Ed Robles, Ferreira do Zezere, Portugal I received the following repair message:
-  It was playing for about 15 minutes, and than it stopped playing, after some hours the same happened.
-  We found out that one of the 3 transistors AF117 caused this problem, we replaced the transistor by another of the same type (a used one). With this trasistor the radio kept playing a litle longer, but after about an hour it also stopt playing.
-  This type of transistor has 4 connections, one off is connected with the metal cage of the transistor, and is meant to reduce interference.
-  By disconnecting this 4th wire from the printed-circuit, the problem was solved, we also disconnected this wire of the other 2  AF117 transistors, just in case.
-  For so far I don’t hear any difference of interference.
