boonton: 219A; FM Stereo Modulator: Mains socket
? boonton: 219A; FM Stereo Modulator: Mains socket
14.Jul.15 20:04
19
Officer
Articles: 1735
Does anybody knows this mains plug from the Boonton Stereo Modulator 219A:
I'm looking for a matching mains cable or the socket alone. The pins measure 3.3 mm in thickness, inner dimensions of the plug are 26.5 x 13 mm, outer pin spacing is 16 mm.
Maybe a common connector in the early 1960s, but nowadays [at least in Germany] no longer obtainable.
Thanks for looking,
Bernhard
Also used by H&P
14.Jul.15 22:15
19 de 2819
Articles: 2129
Count of Thanks: 4
Hello Mr. Nagel.
H&P use in Europe the same Mains-Connector.
See here-
and also here
and in many more Models. in  the sixties. One sample named "BELDEN" 7A 125V
or one. "dL"  (only)  ðL
Regards Knoll
Power cord
15.Jul.15 15:01
92 de 2819
Officer
Articles: 1735
Count of Thanks: 2
Thanks, Mr. Knoll!
Indeed, this connector also has been used with other equipment. Found a picture in the www:
Maybe someone has such a power cord available which is no longer needed, thank you.
