brandes: Brandes B-16
? brandes: Brandes B-16
05.Apr.13 06:56
123
Howard Mariotti (USA)
Articles: 51
Count of Thanks: 5
Howard Mariotti
The picture on the model page is accurate and matches other pictures of this model that I have seen online.  I found this model but with a very different cabinet, made by Adler Manufaturing.  Mine is, unfortunately, a basket case.  It does, however, have some historic significance because it appears genuine and not modified.
Does anyone recognize this cabinet or have suggestions on how the pictures of my model should be filed?
Thanks, Howard
new model entry
24.Apr.13 19:00
123 from 2493
Mark Hippenstiel (D)
Articles: 1250
Count of Thanks: 6
Mark Hippenstiel
Dear Howard,
we have a number such cases where sets were built into cabinets by different manufacturers. We kepp them as separate model pages.
In general, the model entry has to be made under the according radio manufacturer, i.e. Brandes. The model name will be B-16, and in the model type section you should write "with Adler-Royal cabinet". Other data you'll have to provide from the set. If you're unsure about anything, please contact me via email, I'll help you sort things out.
The first step now is to make a new model suggestion. Best is to have all the data at hand before you start with that.
Best regards
Mark
Thanks
29.Apr.13 05:50
176 from 2493
Articles: 51
Count of Thanks: 4
Howard Mariotti
Thank you Mark.
I will get all the cabinet dimensions and data together.
Howard
