braun: 300UKW; Phono-Super
         I also received pictures of the radio and should add that the tube complement shown on the back panel agrees with that of the model page.
Which one is correct or are there different versions?
Is it possible without major modifications to spindle and drive wheel to adapt the record player to 60Hz?
Thanks for any information someone may have on this.
AZ
Variant EABC80?
The given catalogue, "Katalog des Rundfunk-Gross-Handles 1952/53, shows on page 33 the tubes listed. So this model will have to stay - as a variant EAA91 - because I presume that your model can show an EABC80 instead and must therefore also have some other valves.
I did now copy this model and made a variant EABC80. If my guess is not true we can change this without any problem. I would be very glad if you could list the valves of your model as an answer here and perhaps even change whatever has to be changed on "your" new variant:
http://www.radiomuseum.org/dsp_modell.cfm?model_id=75125
I wonder what sort of tubes the set has which is shown here ... Maybe the same as yours?
And: Is yours a local set or made for export? Regarding to your question it is made for Germany or Europe anyway. You surely noticed that there is also model 300 UKW without built in record player (phono) plus. And there is a 300 UKWF - probably with the tubes you find in your set: ECH81, EF85, EABC80, EF80, EM11, EC92 and EL41.
Phono-Super variants
         thanks for the quick reply. From your explanations, it has become clear that I will have - I have not yet taken physical possession - the EAA91 version.
To avoid future confusion, it would seem appropriate to move the EABC80 schematics from the EAA91 model page to the newly created "Variant EABC80" page. (I would do it if I knew how. You are aware of my shortcomings in this and related areas). What I will do is to enter the tube designations on the new EABC80 page (as taken from the schematics currently attached to the EAA91 page.
To my other question about modifications to the record player, I can confirm that the set was made without any doubt for the home market. Dial glass with station names rather than frequncy ranges bears this out. I also happen to know that the radio comes out of an estate sale in Germany and was used there for many years. It is, therefore, reasonable to assume that the drive was designed to operate on 50Hz. Voltage could be another problem.
Thanks and Merry Christmas!
Version EAA91
Thank you, merry Christmas too - a bit later than us ... ;-)
BRAUN - Radio, 300 UKW PHONO
Hello Mr. Alfred Zeeb,
please, did have your set 2 x SW realy ?
And, the dial glass is in english or german language ?
Friendly greetings !
Hallo Herr Zeeb,
hat Ihr Modell tatsächlich 2 x KW ?
Ist die Scala in englischer oder deutscher Sprache ?
Freundliche Grüße
Hanschke Reinhard
         Hallo Herr Hanschke,
mein Geraet, EAA91 Version, ist zweifellos (und wie oben ausgefuehrt) eine Inlandsausgabe mit deutscher Skala.
KW ist nur einmal vorhanden und umfasst den Bandbereich 25 - 50m. Siehe Abbildung. Vielleicht kann einer der Experten bei Gelegenheit die Modellseite in dieser Beziehung auf Richtigkeit pruefen.
Leider ist mein Geraet wegen Zinkfrass am Drehko nicht betriebsbereit. Brauchbarer Ersatz war bislang nicht aufzutreiben
BRAUN 300 UKW Phono
vielen Dank für die schnelle Antwort und vor allem auch, daß Sie in deutscher Sprache schreiben. Meine englischen Sprachkenntnisse sind wohl nach meiner eigenen Meinung nicht die Besten !
Ich habe mich nach einem beispielhaften Beitrag von Herrn Georg Richter gehalten und anschließend auch in deutscher Sprache geschrieben, denn nicht jedes Mitglied ist wohl perfekt in der englischen Sprache wobei das amerikanische Englisch wiederum seine Besonderheiten hat.
Doch zur Sache:
Ich habe u.a. folgende Geräte von BRAUN:
1. 300 UKW Phono mit der (u.a.) EAA 91
2. 300 " " (u.a) EABC 80
3. 300 " - " EABC 80
4. 400 " -
Mir ist aufgefallen, daß beim Modell ID 75125 dort als Wellenangabe 2 x Kurzwelle steht. Herr Erb hat dieses Modell angelegt und für die Datenherkunft Sie benannt. Nachdem in der Literatur (Großhandelskataloge) für die Geräte zu o.a. 1 - 3 keine 2 x KW benannt sind, wollte ich durch meine Anfrage ausschließen, daß es sich bei Ihrem Modell eventuell um ein Export-Gerät handelt.
Durch Ihre Antwort kann ich nun dazu übergehen, eine "ordentliche Flurbereinigung" in Sachen 300 UKW PHONO zu machen.
Denn, das Gerät lautet z.B laut dem Typenschild auf dem Chassis zu o.a. Ziff. 1 richtig: W 300 UKW PHONO. Das Foto bei ID 19198 zeigt m.E. in Wirklichkeit den 400 UKW mit dem Schalter rechts. Herrn Kaulfuß, der die Bilder dazu hochgeladen hat, erreiche ich erst am kommenden Sonntag. Es wäre noch einiges aufzuführen.
Wenn ich Ihre Frage an Herr Erb richtig verstanden habe, haben Sie sich bei Herrn Erb wegen 60-Cycles-Problem erkundigt. Ich kann mich erinnern, daß damals es für Plattenspieler oder Tonbandgeräte 60-cycles-spindel an die hier stationierten US-Soldaten verkauft wurden. Wie das heute geregelt ist mir nicht bekannt, nachdem ich seit 41 Jahren in dieser Branche nicht mehr beschäftigt bin.
Zum Zinkfraß: Also meine beiden Braun 300 UKW PHONO haben keinen Zinkfraß und spielen. Einer hat leider keinen Plattenteller.
Nochmals vielen Dank für Ihre schnelle Antwort, verbunden mit vielen Grüßen !
Reinhard Hanschke
