zenith: can not locate loud humming only
? zenith: can not locate loud humming only
j8980 model just loud hums, all caps are good
Dear Michael,
Are you sure that you changed the filter caps (Electrolyte Capacitor Block) too? This is the aluminum block C1 in the upper left corner, see attached diagram.
Regards,
Rolf
Attachments:- can not locate loud humming (276 KB)
Count of Thanks: 4
Dear Michael,
If you are still having problems with humming the first thing I would look at is the ground connection for all electrolytics.
If you have a scope, measure the freq. and post that in your problem description.
I have not changed C1, I will look at that not sure where I could fin one, but I could make one I suppose.
thank you
Dear Michael,
Please have a look at Antique Electronic Supply. They have a Capacitor - 500V, 32/32µF.
Regards,
Rolf
