Circa 1920 tubes
Circa 1920 tubes
22.May.23 18:28
141
Max Frister (USA)
Count of Thanks: 15
A friend gave me some old tubes.  I think they are rare enough that I wanted to share them with the board.  Let me know if further pictures would be helpful
Tube 1:
Envelope: Clear tubular with beak on top
Marked (etched) “E.R. 50 5549
Base Brass
Pins short UV style
Bottom lathe turned bakelite with “S” embossed in center
Assume this is an an “Electron Relay” made by “moorehead laboratories”.  Might be long anode version of gas triode.
Tube 2:
Envelope:bottle shape with gold and rainbow color.
Glass beak on top
Marked (ink?) GE logo on glass
Marked paper decal with Cunningham “C”
Base brass
Pins short UV style
Bottom Ceramic with “32” in center
Base marked on 1 side
CUNNINGHAM
AMPLIFIER
TYPE C-301-A
PATENTED
9.  Base marked on 2nd side:
….NSED ONLY FOR
AMATEUR EXPERIMENTAL
AND ENTERTAINMENT USE
AND ONLY TO THE EXTENT
INDICATED ON THE CARTON
Assume this is the Cunningham version of the UV-201A
Tube 3
1.Glass Envelope: tubular with red color (nearly opaque)
2. No markings on glass
3. Brass base
4. Bottom paper
5. Pins short UV style
6. Base marked:
Le De Luxe
Vn. (?) 11
D’ Amplification
Assume this is a triode tube made by “Le Radion” in Chicago.
Tube 4
Envelope: glass bottle with beak silver color
Paper RCA meatball label
Etched with W in circle with “W.L. Co.” below “W”
Brass base
Ceramic bottom with “24” embossed in center
Base marked 1st side
    RADIOTON
    MODEL UV 201 A
    PATENTED
Base marked 2nd side
LICENSED ONLY …
Assume this is a Wester Electric UV 201 A
Circa 1920 tubes
25.May.23 06:16
141 from 2846
Nikolaus Löwe (D)
Articles: 231
Count of Thanks: 5
Nikolaus Löwe
Hello Max,
Nice find! These are some seriously early tubes.
I am particularly intrigued by the Le Radion one, as we don't seem to have it listed here on radiomuseum.org.
The only tubular valve by that company that I can find is this one:
Unknown_LeRadion , Tube Unknown_LeRadion; Röhre Unknown_LeRa | Radiomuseum.org
Could you maybe supply us with more detailed pictures of the tube and its label? We might have either a new tube here, or at least a new package. All other documented types are tennis ball-shape.
Yours,
Nikolaus Loewe
