clinton: 19SQ Electrolytic Capacitor
This article refers to the model: 19SQ (Clinton Mfg.Co.; Chicago, IL)
? clinton: 19SQ Electrolytic Capacitor
03.Mar.15 02:32
67
Joseph Gates (USA)
Articles: 4
Count of Thanks: 5
Hello,
I am having a difficult time identifying (without a schematic) the number of capacitors wrapped up in this rectangular box on the top of the chassis.
There are 6 wires coming out of it and I've identified that there are at least 2 separate caps.
What I need help with is: are there more than 2 caps
What are the possible values for these
I've enclosed some pictures!
Thanks for your consideration!
More than two
03.Mar.15 12:10
67 from 1544
Michael Watterson (IRL)
Articles: 1099
Count of Thanks: 5
It's got a voltage doubler, so probably at least one cap  has a separate connections to the others.
Likely there are 4 to 6 capacitors and values of 8uF to 16uF.
If it's pitch filled it can set in and old pot on supports and heated (electric grill, oven, heat gun, not microwave or gas).
Then you'll find what is in it. Often with suitable DC via current limit resistors old Electrolytics reform. They need replaced even on oldest sets much less often than paper dielectric non-polarised types, if they haven't dried out.
voltage doubler
03.Mar.15 12:52
79 from 1544
Kurt Schmid (D)
Articles: 61
Count of Thanks: 4
Kurt Schmid
Hi,
this definitively is a voltage doubler circuitry. The enclosed schematics shows a similar arrangement with a dual 25Z5 rectifier (both diode sections are connected in parallel) and a type 43 final tube. Watch the capacitor from screen to plate.
