Color sign upon carbon resitors BEYSCHLAG germany
Elements: carbon coated resitors.
Colour identification of resistors in radial and axial design, of the company DR. BEYSCHLAG in Holstein Germany.
At the beginning of the fifties, Schaub -Lorenz and north Mende beside the well-known types of Rosenthal and NSF, resistances of a new company preferably emerged with GRUNDIG.
Were products of Dr. BEYSCHLAG.
Two characteristics are noticeable at these parts, once the salient dark red bodycolor and with the radial types color points and with axial colour rings. These colors have with those in the USA (now international) and did not admit to do COLOR CODE to those from the French area at all.
What is it then?
If someone looks in the wiring of a radio or TB equipments, filled with construction units, for an orientation around there an analysis to make to seize is one forced each value numerically i.e. it must each value on the part is read off.
The company BEYSCHLAG there which be occurred let itself. One divided the groups of values from 10 ohms to 22 Meg ohm in color's groups. The experienced technician had if it a certain value looked for, first only the color to focus and then the value only with this to read off. If you reconstruct that, you the advantage will immediately recognize. On printed circuit boards lie side by side often up to 10 of resistances, there is a large assistance mean I.
Bauelemente: Kohle Widerstände
Farbkennzeichnung von Widerständen in radialer und axialer Bauform der Firma
DR. BEYSCHLAG Heide in Holstein.
Anfangs der fünfziger Jahre tauchten vorzugsweise bei GRUNDIG, Schaub -Lorenz und Nord- Mende neben den bekannten Typen von Rosenthal und NSF, Widerstände einer neuen Firma auf. Es waren Erzeugnisse von Dr. BEYSCHLAG.
Zwei Merkmale fallen an diesen Teilen auf, einmal die markante dunkelrote Körperfarbe und bei den radialen Typen Farbpunkte und bei den axialen Farbringe.
Diese Farben haben mit denen in USA ( jetzt international) und denen aus dem Französischen Raum bekannten FARBCODE überhaupt nicht zu tun.
Was ist es dann?
Wenn man in die Verdrahtung eines mit Bauteilen angefüllten Radios oder TB- Gerätes nach einer Orientierung sucht um dort eine Analyse zu machen , ist man gezwungen jeden Wert numerisch zu erfassen , d.h. es muss jeder Wert auf dem Teil abgelesen werden.
Die Firma BEYSCHLAG hat sich da was einfallen lassen. Man hat die Wertegruppen von
10 Ohm bis 22 Meg Ohm in Farbgruppen eingeteilt.
Der erfahrene Techniker musste wenn er einen bestimmten Wert suchte, zunächst nur die Farbe anpeilen und dann den Wert nur bei diesem ablesen.
Wenn Sie das einmal nachvollziehen , werde Sie sofort den Vorteil erkennen.
Auf Leiterplatten liegen oft bis zu 10 Widerstände nebeneinander, da ist das eine grosse Hilfe meine ich.
not finish!
Hans,
Thank you for posting this information. I shall archive this for future reference.
Paul.
