crosley: 618;
This article refers to the model: 618 (Crosley Radio Corp.; Cincinnati (OH))
crosley: 618;
28.Feb.07 03:50
Dale Steel (USA)
Articles: 5
Count of Thanks: 16
Dimensions  WHD
W- 11 inches
H- 20 inches
D- 20 inches
Providing new information for a model
28.Feb.07 07:12
Thomas Albrecht (USA)
Officer
Articles: 378
Count of Thanks: 10
Thomas Albrecht
Hi Dale,
Thanks for making these measurements and sharing the information with RMorg.  When you want to provide new information for a model, here's the way to do it:
From the main search page (the home page), enter the manufacturer and model number, which will then take you to the model page for the Crosley 618 (http://www.radiomuseum.org/r/crosley_618.html).  At the bottom of the page, you'll see a link for "Suggest change" and you should click on it.  On the page that then comes up, click on "Suggest a change" and then you'll be taken to a page where you can enter new information for the model.
After you submit the information, an administrator will verify that the format is correct and the information is reasonable (this will catch mistakes that we all make from time to time).  You can check the status of your proposed changes by clicking on Administrators on the left side of the main search page (the home page).  Within a day or two, an administrator will check the information, and either accept the changes, or reject them with an explanation to you.  You'll receive some automatic emails when this happens.  Finally, after acceptance, you'll see the information you provided appear on the model page, where others can benefit from what you haev provided.
The process may seem a little complicated the first time you try it, but after that it's easy!
Best regards,
Tom
05.Mar.07 14:50
Articles: 2316
Count of Thanks: 15
Since nothing happened following Toms recommendation I took the action and put the info to the model.
