feeltech: DDS Function Generator FY6900: Teardown review
19.Nov.20 16:35
12933
Jose Mesquita (P)
Articles: 111
Count of Thanks: 71
Jose Mesquita
This series of FY6900 signal generators were announced by FeelElec around 2019 on eevblog and this model toghether with the previous FY6600 are probably the most dissected and discussed SigGen in the forums for the good (low price, good specs, diy mods) and bad (questionable fiability, bugs and the infamous 4nS jitter) reasons.
FeelElec has announced this model as an upgrade of the FY6600 series where features like MagicPulse Technology with Low Jitter(RMS)<200ps, more than 100 Waveforms: 8192 points * 14bits, and 0~24Vpp output amplitude range,with minimum resolution of 1mV.
This FY6900 consists of these main assemblies: The Power Supply, the Main PCB (Signal Board), and the Front Panel PCB (MCU Board).
The Switching Power Supply may be adequate to support the requitred current consumption of the +5V and +13.5V and -13.5V, but it is probably the weakest part of the unit.
There are at least two Signal Board PCB revisions: V1.8 and V1.9, where the V1.8 still used the Altera Cyclone 4 FPGA, and V1.9 started to use a FeelElec-PRO 1941 FPGA and a Fan power supply header was included (despite no Fan is supplied up to Nov-2020).
There are also two known PCB revisions for the MCU Board, V1.8 (that goes with Signal Board V1.8), and V1.91 (That goes with Signal Board V1.9).
The known firmware releases are 1.2, 1.3 (around Nov-2019), and 1.4 (around Oct-2020). The management firmware is selfcontained inside the Front panel MCU Board MCU IC (STM32F103C8 ARM Cortex-M3 32-bit MCU 64KB Flash). Howeve the signal shaping firmware for the FPGA is contained inside a Winbond 25Q16JVS10 Flash ROM IC in the Main PCB Signal Board. FeelElec reports that firmware upgrades are done at the factory only (they can sell the two ICs (MCU and Winbond Flash) for those able to use a solder iron). That said, some customers have reported that they were able to update the firmware online by using the PC Software v6.5 (FY6900 remote control software) by installing the available PC Software V6.3 from FeelElec website, then do a online update to 6.5, and finally updating the firmware from 1.3 to 1.4 (firmware below 1.3 do not support online updates), but FeelElec has reported that this method was in beta testing and should not be used until the PC Software 6.5 is stable to be officially released on their website (this was the response from my AliExpress seller yesterday, Nov-18, 2020).
Some anomalies were reported on the forums, like:
  • The electromagnetically noisy Switched Power Supply supplying the +13.5V & -13.5V used by the high voltage output Opamps for the lower frequencies. This noise is also visible on a scope set to 5mV/div by selecting zero volt from the Signal Generator: a complex pattern with 67KHz 2mVpp bursts consisting of very high RF frequency and a minor 50Hz modulation as well is visible; swithing off the Signal Generator eliminates this noise. Some of this noise is coming from the SPS, other RF high frequency are most probably coming from the LSI chips.
    • This SPS is not shielded in a metal case and the output power cable is not filtered with any sort of ferrite clips or similar noise killing devices. Also the SPS PCB is installed very close to the Signal Board.
  • Distorted squarewave above 5V signal output for frequenciess of 10MHz and above, a clear indication of the poor Opamps implementation used in the high voltage section of the output amplifier;
  • Non normalized 86 Ohm attenuator pad for outputs below 500mV (50 Ohm should be the accepted nominal value);
  • Output DC Offset is not zero Volts for all frequencies and voltages, a minor issue.
FY6900 Parts list
Front Panel PCB V1.91 (Managemnent Board)
U1       STM32F103C8 ARM Cortex-M3 32-bit MCU 64KB Flash
SU1    AMS1117 3.3 LD918    3.3V Regulator
XTAL  8B000G4CP        8MHz oscillator
LS1    Buzzer
LCD   Standard ILI9341 ?
FS1    8-pin Connector to MCU
J1      4-pin Connector to MCU: RXD, TXD, GND, 5V  USB to serial CH340 on the main board
JK1    4-pin header  to MCU. GND, 3V3, JTCK, JMS
Note on JK1: It could be used to connect the MCU to an external  programmer like the "ST-Link V2 programmer" to R/W the STM32 MCU Flash memory.
Main PCB V1.9 (Signal Board)
U2    FeelElec-PRO 1941    FPGA
U?    DAC904? 165MHz overclocked to 250MHz
U16  CETECJ 10.000 166    4-pin SMD 10MHz Oscillator close to FPGA
U?    Winbond   25Q16JVS10 8-pin SMD Flash ROM close to U16 and FPGA
U?    MCP4822E SN 2017 8-pin SMD after FPGA
U?    AD8009 ARZ #549  8-pin SMD low voltage Opamp after DAC904 & LBPF
U?    4556A JRC  8-pin SMD Opamp after 2 x MCP4822E
U?    3002I 3VT  8-pin SMD high voltage output opamp
U7    HC245 XR00611  20-pin dip SMD close to back panel, rear side of FPGA
U?    4558D JRC  8-pin SMD close to U7
U?    CH340G  16-pin dip SMD  for USB / Serial I/O
U?    12.000  12MHz Crystal
U13    AMS1117 1.2  1.2V REG SMD
U20    AMS1117 2.5  2.5V REG SMD
U14    AMS1117 3.3  3.3V REG SMD
T5    79L05  -5V REG SMD
T2    78L05  +5V REG SMD
RL1    EA2-5 NEC Relay output
RL2    EA2-5 NEC Relay output
RL3    EA2-5 NEC Relay output
RL4    EA2-5 NEC Relay output
ID1    T4  Diode close to relay
ID2    T4  Diode close to relay
ID3    T4  Diode close to relay
ID4    T4  Diode close to relay
Q9    J3Y  3-pin TR close to ID1
Q10    J3Y  3-pin TR close to ID2
Q11    J3Y  3-pin TR close to ID3
Q12    J3Y  3-pin TR close to ID4
A1    C14J  5-pin SMD close to Q8
Q8    A7  3-pin SMD close to Counter input BNC
Q5    J3Y   3-pin TR close to T2 78L05 REG
T1    A19T 3-pin TR close to Q5
