ECH4A (ECH4A)
? ECH4A (ECH4A)
30.Apr.09 21:29
Articles: 1774
Count of Thanks: 20
Fortunately we could find out information about data and origin of the before mysterious ECH4G.
Now the secret of this ECH4A is yet to be solved.
Because of the straight bulb shape the ECH4A may probably be an Octal version of the E1R ?
Can anybody confirm this, e.g. by comparing the data ? Even checking the heater current will give some evidence, since the heater current of the E1R is only 0.2 A, while the heater current of the normal ECH4 is about 0.35 A.
Best regards,
Jacob
ECH4A vs E1R
30.Apr.09 22:02
Emilio Ciardiello (I)
Articles: 526
Count of Thanks: 23
Emilio Ciardiello
Dear Jacob,
Ravalico gives the E1R as an ECH3 with modified base connections that are the same of ECH4. The ECH4A is given as electrically identical to ECH4, with octal base and cylindrical bulb. The two tubes, E1R and ECH4A, seem to have different origin according to the above source.
Best regards, Emilio
Clarity about the ECH4/34 family
06.May.09 10:05
Articles: 1774
Count of Thanks: 21
Dear Emilio,
thank you for this useful information.
About the same matter, I found additional information on this site: Le valvole convertitrici di frequenza .
After some research I could get more clarity about the ECH4 family, particularly about their octal versions. I hope, any open questions before, are now answered.
Since the Ex3x- series is the most common series of red-series octal tubes, I'll call the ECH34 as reference tube.
As usual in this series, the heater connections are on pins 2 & 7, according to the normal (American) octal standard.
The other ECH4 octal versions are in relation to the ECH34 as follows:
ECH4G = Australian version of the ECH34. Equivalent to the ECH34, but with golden painted bulb.
ECH4A = Italian version of the ECH34. Equivalent to the ECH34, but with straight GT-style bulb.
ECH4K = By now only found in some Swiss radios. Equivalent to the ECH34, with exception of the base diagram, which is the same as of the UCH4, with heater connections on pins 1 & 8.
E1R : With exception of the same base diagram as the ECH4, the triode-hexode E1R doesn't belong to the ECH4 triode-heptode family. It's merely an ECH3 with the base diagram of the ECH4 !
The relation of the E1R to the ECH3 is similar as the relation of the 6TE8 to the 6E8: E1R and 6TE8 are triode-hexodes with independent units.
Best regards,
Jacob
