Eddystone: RF gain potentiometers logarithmic
28.Apr.07 22:51
3847
Martin Bösch (CH)
Articles: 618
Count of Thanks: 13
Martin Bösch
In Eddystone User Group Newsletter 50 I found the following useful information an replacing RF gain pots in Eddystone receivers:
Usually AF gain pots are logarithmic carbon types, RF gain pots usually used linear wire-wound types.
After replacement of RF gain potentiometers with common linear ones, many listeners found that the whole RF gain control range was passed through in the last eigth of a turn.
A careful inside inspection of a Eddystone RF gain pot revealed, that in that wire wound potentiometer three different thicknesses of resistance wire had been used. The first third in 10 kOhm pot is linear 0 - 500 Ohms, the second third 0 - 2000 Ohms, the third bit 0 - 7500 Ohms, so the whole makes 10000 Ohms.
So consider trying to clean out Your Eddystone RF - gain pot instead of simply replacing it with a 10 kOhm linear one, otherwise Your RF-gain control might suffer from the "Switch Syndrome"...
Hope that helps, kind regards Martin
