EL90/6AQ5/6005 to replace EL95's
? EL90/6AQ5/6005 to replace EL95's
15.May.11 22:53
Omer Suleimanagich (USA)
Articles: 422
Count of Thanks: 48
Omer Suleimanagich
Does anyone out there have experiance replacing EL95's with EL90's?
With all these amazing table radios and consoles being produced in the late 1950's and 1960's, it seems that the EL90 gives out a bigger kick than the EL95's!
6BM5 OR 6AK6
16.May.11 03:34
8 from 13323
Articles: 422
Count of Thanks: 29
Omer Suleimanagich
I found some threads and forums that describe a, 6BM5 as a direct replcement for an EL95, and a 6AK6 as a replacement with modifications necessary to the tube base.
EL90 is less economical than EL95
16.May.11 12:18
42 from 13323
Jan Terranea (NL)
Articles: 63
Count of Thanks: 24
Jan Terranea
The EL90 tube draws 45 vmA at 250 volts DC into a 5 K.ohm output-transformer, while the EL95 draws 24 mA into a 10 K.ohm output-transformer.So in many cases a direct replacement is not possible, also because of the higher heater- consumption and  the fact that the EL90 is taller.
6BM5/EL85
16.May.11 19:09
100 from 13323
Articles: 422
Count of Thanks: 27
Omer Suleimanagich
EL95, EL85 and EL42
17.May.11 11:08
154 from 13323
Jan Terranea (NL)
Articles: 63
Count of Thanks: 39
Jan Terranea
The EL85 and EL95 are successors of the economical rimlock EL42 power-amplifier, designed for car-radios, having the same high tension and heater-consumption, with different bases. I have no experience with the EL85, but I do with the EL95 which was very common here.
18.May.11 21:56
208 from 13323
Articles: 1786
Count of Thanks: 18
