ericsson: PAUTHX 92203; M-PA UHF
There are three versions of this radio (not counting the 'splits'). The Select, Scan, and System. The Select radio has no keys on the front panel under the display and is capable of only 16 channels and is incapable of scanning. The Scan model has four keys on the front panel, can scan and can be programmed with up to 192 channels (12 modes of 16 channels or 16 modes of 12 channels). The System model has the same four keys the Scan model has and also a 3x4 "DTMF" keypad. The System model can scan and can be programmed with up to 192 channels (12 modes of 16 channels or 16 modes of 12 channels).
All UHF models of MPA meet the MIL-810C and D specifications.
http://www.radiomuseum.org/forum/what_is_accepted.html
