eumig: 386W; Phono Eumig 3D Record Player
? eumig: 386W; Phono Eumig 3D Record Player
21.Nov.10 09:53
Bob Isaac (USA)
Articles: 107
Count of Thanks: 11
Bob Isaac
Hello Friends,
 Does anyone know how to adjust the RPMs of the record player? There is a noticable 'slowness' on the 33 1/3 setting and I can find no information in the service documents.
Thank you,
Bob
Dual 300 ?
21.Nov.10 10:59
8 from 3165
Articles: 2321
Count of Thanks: 9
I assume that this is a Dual 300 turntable.
Since nothing can be adjusted
They are friction wheels, which may need to be oiled.
Perhaps the motor bearings needed to be lubricated.
Regards WB.
Success!
21.Nov.10 15:59
52 from 3165
Bob Isaac (USA)
Articles: 107
Count of Thanks: 9
Bob Isaac
Thank you Herr Bauer, you are right on the money!  I disassemble the drive wheel assembly and carefully removed all of the old and sticky oil from the wheels, inside chambers and shafts, then coated the axle shafts with fresh light oil.  The turntable (yes, it is the Dual 300) plays at the correct RPM (as far as my ear can discern) on all settings (78, 45 and 33 1/3 - I don't have any vinyl records at 16 RPMs! so I'll assume it is OK!)
Thank you again for the very useful suggestion!
Your Friend in Radio,
Bob Isaac
Printable Strobe disk
21.Nov.10 20:20
90 from 3165
Paul E. Pinyot † 2013 (USA)
Articles: 184
Count of Thanks: 11
Bob,
This site: click here has a PDF printable strobe disk that you can use.  Just shine a flickering lamp on it like a flourescent or neon lamp.  I use my bench lighted magnifying lamp.  It flickers with the line frequency better than any CFL.
They have both 50 and 60 Hz printable strobe disks.
Paul.
Thanks!
22.Nov.10 12:38
118 from 3165
Bob Isaac (USA)
Articles: 107
Count of Thanks: 9
Bob Isaac
