ever: N3; Power Switch
This article refers to the model: N3 (Ever Ready Co. (GB) Ltd.; London)
29.Feb.12 10:21
2349
The power switch actually switches the 1.5V and 90V Battery negative connections. The yellow wire is from B107 90V pack and when switch closed (lid open) it's connected to chassis / 0V via 560 Ohms to provide bias for the DL96 grid which is connected to the yellow wire via 2.2 M Ohms.
It wasn't connecting HT- or LT- due to corrosion and wear. The contact at 0V end of 560 Ohms was corroded and also cracked. It was replaced with a small cut-up piece of battery clip from a €2 scrap Auto Scan FM Radio.
The yellow wire only connects to the resistor, no contact. The green wire contacts underneath.
- Yellow = B107 HT- via a tag strip
- Green = Direct to earth tag on Chassis near first IFT
- Black = Direct to AD14 LT- connector
