Finding replacment capacitors on old Hallicrafters S-40A
? Finding replacment capacitors on old Hallicrafters S-40A
11.Mar.09 22:41
Dave Turner (USA)
Articles: 46
Count of Thanks: 29
I have the part numbers for several manufacturers to replace the original "Can" capacitor on this model, but wondering where to search for the part numbers that I have available to me.
The numbers are: Hallicrafters 45A062, Solar DY-400, Sprague El-344 & UT-8 and finally, Cornell-Dubilier UF43145C.
Seems like valuable information, but I don't have a clue how to look for these parts.  I suspect they are obsolete, but someone might have one.
Any thoughts greatly appreciated.
Dave T.
Hallicrafters S-40A
12.Mar.09 05:42
Thomas Albrecht (USA)
Officer
Articles: 378
Count of Thanks: 28
Thomas Albrecht
Hi Dave,
I think your question probably should be posted from the model page for this receiver:  Hallicraft_s_40a .  Use the link "Add information or ask a question..." that you see at the bottom of the model page.
It's not always easy to tell which part of the forum to post a question in.  Here you've made what would appear to be a very reasonable choice (HAM radios), but since your question applies to one specific model, it's really best to post from the specific model page for that radio.
The reason for this is so others who bring up information on this radio in the future will see this forum question and the answers provided.  Sometimes that can save someone else a lot of time.
I can look up some info on this capacitor and provide some options for replacement.  If you repost from the model page, I'll put the answer there.
Thanks for your patience!  :-)
Tom
Hallicrafters S 40A Capacitors
12.Mar.09 13:11
Dave Turner (USA)
Articles: 46
Count of Thanks: 25
Thanks Tom,  I'm still new to this forum, I'm trying to learn my way around.
I do appreciate the help.
Dave Turner
Replacement values - filter capacitors - Hallicrafters S40-A
20.Mar.09 01:08
John Bartley (CDN)
Articles: 2
Count of Thanks: 32
Dave,
The multi-section capacitor you wish to replace is a three section 450vdc unit composed of the following values :
C27 - 10uf
C50 - 30uf
C51 - 10uf
While you might be able to find a replacement three section for these, you might be farther ahead to simply gut the existing can and place three seperate capacitors inside the can, bringing the leads out the bottom to a terminal strip.
cheers
John
The thread sticks not to the model
20.Mar.09 08:01
Officer
Articles: 5755
Count of Thanks: 19
Dear Dave
Thomas was right - but good answers followed - since nobody closed it here ;-)
I have now moved the thread to the model. Here it will be able to help other collectors which may have the same problem - and will therefore not vanish ...
This is a unique feature we have here and I hope members will use it as much as possible because it really enhances the model page too.
You are only a member since a few weeks and have already uploaded some pictures which also form now automatically your collection page here. This is the way to do it. I even think it is good to have a model picture like this one instaed of nothing. When you managed to restore the model (to find the right knob could be a problem) I'm sure you will put in a better picture in a large photo (of 1400 pixels hight or 933 pixel width).
This here is also an other "first picture" for a model. Such pictures can help other collectors quite a lot for knowing the exact model or how it should look like with correct knobs etc. If you can, please try to take also the plate or sticker, chassis, back view, scale etc. and if possible with the given max size. You will have to use the quality % in your picture program to get reasonable KBs under 180 KB.
An alternate solution
20.Mar.09 08:44
Emilio Ciardiello (I)
Articles: 527
Count of Thanks: 29
Emilio Ciardiello
Dear Dave,
you can either follow the solution proposed by John or find multisection can capacitors. One source is Antique Electronic Supply, www.tubesandmore.com. A good replacement, with respect to the capacitance and voltage ratings, is the C-EC40-20-20, that is a 40 + 20 + 20 microfarad. You should just see if it is mechanically compatible with the old one.
It is not advisable to look for an original replacement, unless you can measure the actual capacitance of each section. After 50 years of shelf life even a NOS electrolytic capacitor may be faulty.
Regards, Emilio
20.Mar.09 12:48
Dave Turner (USA)
Articles: 46
Count of Thanks: 25
Ernst,  Thanks for this helpful information.  I'm still trying to navigate my way thru this site.  I intend to get some better pictures by and by.  I still haven't quite figured out how to use Infranview as my photo "transfer" program.
Dave
Hallicrafters S 40A Capacitors - Replaced
20.Mar.09 12:54
Dave Turner (USA)
Articles: 46
Count of Thanks: 30
John B. and Emilio C.
Thanks guys for your help.  I thought I had responded to this earlier.   I did replace these caps, by using modern equivalents and placing them inside the old canister.  This was my first attempt at doing this kind of modification.  Took me about 8 hours altogether.  If I was getting paid by the hour I'd be rich, ha.  It looks pretty good, considering.  I had to destroy the whole bottom bakelight section in the can, but the top portion looks completely original.  I cut a piece of dark grey heavy gasket material to replace the bottom bakelight plug in the can, and drilled small holes through it to pass the connections from the caps.  I'd like to include a picture, but my camera doesn't seem to focus so well on closeups.
Thanks again for all the suggestions and advice.
Dave
Other thread on this subject
20.Mar.09 19:03
Officer
Articles: 378
Count of Thanks: 19
Thomas Albrecht
For completeness, here is the other thread on this subject, where the questions were previously answered:  http://www.radiomuseum.org/forum/market_wanted_hallicraft_s_40a_s40a_usa.html
Best to ask these kinds of questions from the model page.  Now everything can be found from the model page.
