FM problem
? FM problem
![Mujahid Khan](https://www.radiomuseum.org/image.cfm?image=m_khan.jpg&width=120&height=140)
Hi all:
Graetz Canzonetta 816
AM and SW are working fine. The FM is silent.
Where should I start looking?
Thanks
M Khan
To begin with
To get started:
Check all valves lit.
Change first and then the EABC80 ECC85, check voltage switch switching and BF, check ECH81 tensions, EABC80. In the scheme there are tensions.
regards
Tensions
Hi Mr Molina:
All the valves light up.
I will change and replace the tubes you mentioned. What does "tension" and "BF" mean?
Thanks
M KHan
Start from audio and continue until oscillator.
Hello
I mean concrete measure voltages in circuits, boards and EABC80 ECH81 valves in FM tuner head where is the ECC85,.
BF is low frequency, it is to trace the audio stage to the switch.
greetings.
