geloso: G1/1110U (G.1/1110-U);
For the Model G1/1110U (G.1/1110-U); , the full tube complement is, 12AX7/ECC83, 12AX7/ECC83, 12AT7/ECC81, 4 X EL503. The data plate also states that this U model has a Power Rating of 125 W nominal to 180 W max. Please make the appropriate changes, thank you.
Attachments:- Geloso Front (48 KB)
- geloso data plate (49 KB)
Please make the change proposals by Yourself. That is members business, not admins.
Sorry,
Good luck,
KoBi
Hello Jehu, you can do this work by yourself. Go to the model's page and click on "Suggest change". Then, on the new page, click on "Suggest a change" again.
You will see a list of previous data, that you can modify, delete or integrate.
After having been submitted, the corrected data are reviewed by administrators, and then (generally) accepted and put online.
I recommend adding the picture of the amplifier and the rear tag I see on this thread as well by using the link "Add information to model" and then "Picture".
Please drop a line here after you've done the job.
Geloso G1/1110U
