gonset: 75 Meter Converter - some additional information
This article refers to the model: 75 Meter Converter (Gonset Inc., Waterproof Elect. Co.; Burbank (CA))
09.Aug.08 14:02
2098
I received a very informing text from a guest and think we should add such good texts to the model:
Ernst,
I happened to stumble across this listing on YOUR page - I have one!
It has an output frequency of 1430 kHz, operates with 6vac for the filaments, and anywhere from 85 to 150vdc for the B+ voltage. It is one of the VERY FIRST converters made by Gonset, as the metal band, crimped about the shielded power cable said "GONSETT", which is the CORRECT spelling of Faust Gonsett's name... he only shortened it to GONSET (One "T") for marketing purposes, later on.
It preceded the Super Six, Super 12, and other converters, which allowed you to utilize your existing automobile radio as the I-F strip, detector, and AF output, without having to buy a complete receiver (which would not fit very well in a car, in those days). One obtained the necessary voltages from INSIDE the auto radio, which was ALSO a valved-type. These small converters also came in General Coverage SW versions, CAP (Civil Air Patrol - outside the ham bands somewhat), and low band VHF (10m & 6m).
Best 73
Tom Dailey - WØEAJ
Tom mentioned also "Quite often the Gonset Commander transmitter accompanied it." In the 1953 ARRL Handbook "Commander II" was priced at $ 124.50. It was also designed by Faust Gonsett.
Thank you very much, Tom.
If you can give me more data for the Commander or Commander II including photos I would like to introduce it here too. Maybe you can also send me pictures from your Converter and Commander? Or even better join us and upload your gear? In this case I would like that you are accepted under option 1 (for free) since we are prety sure that you will contribute to the group (RMorg it is not MY page - we are 5000 members ;-) - trying to get a real helpful catalogue up within time ...
Ernst,
Best 73
Tom Dailey - WØEAJ
