GP5 (GP5)
Cet article fait référence au composant : Vers le tube ou semi-conducteur
GP5 (GP5)
27.Apr.07 21:55
Jean Claude Terrat (F)
Articles: 7
Remerciements: 19
Jean Claude Terrat
Triode très haute tension pour la régulation de la source THT d'un tube image couleur.
Ce tube remplace le tude ED500 sur les téléviseurs PHLIPS et RADIOLA équipés du chassis TVC4 (90°-DELTA)
28.Apr.07 02:58
Hans-Thomas Schmidt (D)
Rédacteur
Articles: 536
Remerciements: 11
Hans-Thomas Schmidt
Bonjour Msr Terrat, le GP5 n'est aucun tube américain. Il vient de Svetlana, St. Peterburg, Russie. Le transscription correct dans cette base de données est gp-5 (original : ГП-5)
Beaucoup de salutations, H. - T. Schmidt
Hello Msr Terrat,
the GP5 is no american tube. It comes from Svetlana, St. Peterburg, Russia. The correct transscription in this database is gp-5 (original: ГП-5)
Best regards,   H.-T. Schmidt
Change done
30.Apr.07 22:09
Conseiller
Articles: 5747
Remerciements: 10
Dear Hans-Thomas
Why then in capital letters? I have changed now to gp5 (small letters) and also from common USA to common UdSSR.
30.Apr.07 22:36
Mark Hippenstiel (D)
Articles: 1250
Remerciements: 13
Mark Hippenstiel
Svetlana in their own datasheet (link to PDF on Jogi's Roehrenbude) dubbs this tube "GP-5" in roman letters, this should not go undocumented.
Regards
Mark
30.Apr.07 23:49
Rédacteur
Articles: 536
Remerciements: 12
Hans-Thomas Schmidt
Dear Ernst,
I have not written it in capital letters and no possibility to change it, because it was linked with this forum thread. Thank you for changing, but the correct transcription is with a dash, like in my russian data books.
Best regards,  Hans-Thomas
Thank you, Thomas
01.May.07 00:07
Conseiller
Articles: 5747
Remerciements: 10
Now I understand - and I have changed names.
I hope this is now OK - should we name Svetlana as a maker/brand?
Or is "common UdSSR" correct?
12.Jun.07 09:06
Articles: 1250
Remerciements: 14
Mark Hippenstiel
I am refreshing this thread as my remark was left unanswered.
If a manufacturer designates a tube in roman letters in a datasheet that is clearly intended for the western market we can not possibly speak of a cyrillic designation.
Conclusively, the designation deserves an entry of it's own, very much like the Txxx Tungsram. types we recently (re-) introduced.
Regards
Mark
GP5
19.Jun.07 22:43
Articles: 7
Remerciements: 14
Jean Claude Terrat
Bonsoir,
Voici des photos de la lampe
Jean claude
Pièces jointes:
conclusion and summary
25.Jun.07 00:04
Articles: 1250
Remerciements: 10
Mark Hippenstiel
Bonsoir Jean Claude,
nous avons créé une nouveau lampe GP5, ainsi vouz puvez télécharger l'image du votre lampe à la page.
Voici une liste des lampes similaires que sont documentés dans rm.org:
Now we have created a new GP5, which will hopefully soon hold the images Jean Claude has made.
Here is a list of several of these tubes in the system, and why we have them:
  • gp-5 - correctly transcribed cyrillic designation
  • gp5 - "dummy" (locked) so that the tube is found with the dash omitted
  • GP5 - RTC (La Radiotechnique) version of the gp-5
  • GP-5 - designation by Svetlana USA, see data sheet
Regards
Mark
