graetz-vor: 51W (51 W); Super
19.Feb.08 22:01
Robert Sarbell † 22.3.22 (USA)
Articles: 358
Count of Thanks: 14
Hello Colleagues,
I am in the process of restoring an International variant of this model, and would greatly appreciate it if any member could advise of the exact length of the "wellenschalter shaft" as it emerges from the right side chassis. If I am unable to locate a replacement shaft, I shall remove the piece and have a small "stub" welded onto the end.
Apparently the knob and shaft were broken quite some years ago. As a result, it sat idly for more than 30 years before I recently won it on ebaY.
The seller also had no rear panel, and the klangfarben/bandbreitenregler knob on the left rear side of the cabinet is also missing.
The radio is presently playing with some problems, since a very early technician was not able to replace the EFM11  and he created an adapter to install a small 6C5 triode amplifier in the space for the tuning eye.
I will "retrofit" the eye with a NEW EFM11 . . .after correcting circuit mods.
I will attach some photos of the dial glass to support the forum posting by Herr Jens Dehne
Respectfully,
Robert Attachments:
Export-Model ?
20.Feb.08 06:57
Officer
Articles: 5750
Count of Thanks: 14
Dear Robert
According the scale (only) you may be right that this is a real export model - or a at least a variant. Did you check the naming on the rear too? I also wonder about the power supply.
I think we should create this model page first if it is the case. If technically exactly the same then some wording in the notes could be sufficient - but Jens should decide which way he wants to point out the export model.
I wish you good luck anyway for your not very easy "retrofit" work ;-)
51W Super - International variants?
20.Feb.08 15:48
Articles: 358
Count of Thanks: 17
Dear Ernest and Jens,
Thank you both so very much for your assistance. I continue to research the "L&H" identification for certain skalenscheibes of the Graetz 51W productions. I am intrigued by the possibility that some limited numbers of the lovely "art deco style dial glass" model may have been assembled by the combined efforts of Lowe and Halske - similar to the S&H (Siemens and Halske) Marloffstein.
The only model identification data on my version is found on the right rear corner - a small yellow decal which reads as follows (see the attached photo):
Aufgert Leistung Normsisch 55W. Sparung 92W
   GRAETZ       51W
   Radio            Gerätnummer
                        L845060
The power supply appears to be the original installed netztrafo providing the following voltage selections and current protection:
110-125-150-220-240 volts and  2 small (5x20mm) fuses with ratings of 0,7A and 0,35A respectively.
Is it possible that the ID prefix letter L may refer to the "licensee" who may have been authorized for temporary production of some pre-War Graetz models?
Respectfully,
Robert
NOTE: Virtually every component on the underside of the chassis is original -  nearly every axial capacitor is made by ALWAYS  -  I do not recall ever seeing that manufacturer name on the small parts of my German radios.  Attachments:
51W Export und Technik
22.Feb.08 15:10
Jens Dehne (D)
Articles: 594
Count of Thanks: 14
Hallo Robert,
ein interessantes Thema, da ich schon seit geraumer Zeit zur Technikgeschichte um die Marke Graetz recherchiere.
Ich schreibe aus mangelnder Übung und Bequemlichkeit in Deutsch, um diese Sache nicht zu weit „nach hinten“ rutschen zu lassen.
Zunächst zum Modell und einer eventuellen Variante.
Gerade beim Modell 51W kann ich einige Änderungen im Laufe der Fertigung beobachten. Es sind Kleinigkeiten im Detail, welche sich auch auf Materialmangel in der Zeit des Krieges zurückführen lassen. Dieses Modell wurde vermutlich noch bis 1941 gebaut.
Alle in Berlin gebauten Modelle haben typerscherweise die Gerätenummer als eingeschlagene Ziffern auf den Chassis, allerdings besitze ich auch Modelle vom 51W ohne erkennbare Gerätenummer, möglicherweise war nur ein Papieraufkleber am Chassis, welcher sich im Laufe der Zeit ablöste. Geräte des 51W aus später Produktion tragen dann das gelbe Abziehbild mit rotem Aufdruck des Graetz-Logos, Gerätetyp und Gerätenummer rechts am Chassis.
Ein sehr spätes Gerät des 51W in meiner Sammlung hat anstelle des Graetz-Schriftzuges aus Metall unter dem Magischen Auge auf der Front ein rot-schwarzes Abziehbild. So sieht Robert sein Gerät auch aus, auch der Lautsprecherstoff ist identisch. Es handelt sich also auch bei diesem „Exportgerät“ um ein sehr spät gefertigtes Gerät.
Möglicherweise wurden die Geräte mit diesem Typenschild, welches in dieser Machart auch auf anderen, später gefertigten Modellen wie dem 56GW zu finden ist, in Lunzenau hergestellt. Das „L“ vor der Seriennummer ließe das vermuten. In Lunzenau (Sachsen) wurde während des Krieges ein Auslagerungsbetrieb der Graetz-Werke Berlin eingerichtet, man stellte dort auch funktechnische Geräte her. Nach dem Kriege begann man in Lunzenau wieder Radios zu produzieren, man erweiterte und es entstand der VEB Stern Radio in Rochlitz. Das ist aber eine andere Geschichte….
Informationen aus der Zeit zwischen 1939 und 1948 sind bekanntlich nur sehr spärlich und lückenhaft, besonders für einige spezielle Bereiche. Graetz produzierte ja auch Rüstungsgüter…. So kann man manchmal leider nur vermuten und nach Indizien und Fakten suchen, um das Puzzle zu komplettieren.
Die Skalenscheibe des 51W für den deutschen Markt war braun mit weißer lichtdurchlässiger Schrift. Deutsche Sender wurden auf der Skalenscheibe in „Deutscher Schrift“ dargestellt. Auf der Skala „International“ sind alle Sendestationen neutral in gleicher Schrift und in unterschiedlicher Farbe, welche den Wellenbereichen zugeordnet ist, dargestellt.
Einen technischen Unterschied der Geräte konnte ich bisher nicht ausmachen, eventuell finden sich noch kleine Feinheiten. Leider fehlt die Rückwand. Die Skalenscheibe lässt schon rein optisch einen äußerlich anderes Gerät erscheinen. Vielleicht finden sich noch ein paar andere Merkmale, die ein neues Modell im RM rechtfertigen.
Zu den technischen Problemen an diesem Gerät.
Eine Schwachstelle ist die Nockenwelle des Wellenschalters. An der Rille zur Arretierung an der Chassisdurchführung bricht das Material gern, möglicherweise wegen schlechter Qualität des Eisens. Ich habe kürzlich erst eine solche Welle an einem 51W gewechselt.
Von der Bruchstelle bis zum Ende sind es etwa 4cm. Außerhalb des Chassis ist noch die Mechanik zur Anzeige des Wellenbereiches montiert. Dazu werde ich noch ein Foto nachreichen.
Soweit erst einmal ein paar Informationen von mir.
Viel Erfolg beim Restaurieren!
Jens Dehne
PS: Ich schaue, ob ich die fehlenden Teile auftreiben kann….
51W International model and Technical details
22.Feb.08 16:16
Articles: 358
Count of Thanks: 15
Grüße und viel Dank Jens,
Ich habe die ganze Ihre Antwort übersetzt und las. Die Graetz Produktion Geschichte ist sehr interessant, und ich bin zu eigenem das schöne Modell sehr glücklich. Die Stromkreise sind zu denen fast identisch, die im SABA 455WK Modell von 1938 gefunden werden, und es hat auch das "Art Deco" Vorwahlknopfglas.
Ich setze eine Kopie dieser Informationen in die Datenbroschüre, die ich für jeden Radio vorbereite, den ich wieder herstelle.
Vom Sichtaussehen meiner Version 51W und der Details, die Sie, ich beschreiben, kann verstehen, daß etwas begrenzte Produktion der Modelle so bald wie möglich erscheinen würde, nachdem die Produktion der Bewaffnung Einzelteile durchgeführt wurden. Ich habe die einige unterschiedlichen Teilnummern auf den Vorwahlknopfgläsern beachtet, die in den vorbildlichen Datenfotos bildlich dargestellt werden. Auf meinem Empfänger funktioniert die normale Energie und dann Wirtschaft noch entsprechend dem Diagramm - wenn das Sparungschalter entweder 198 Volt oder 354 Volt bereitstellt.
Der Empfänger arbeitet momentan gut auf dem KWII Band und gestern Abend, die ich zu den englischen Nachrichten Getrieben von internationaler Radioukraine und von Rumänien innerhalb der 41 und 59-Meter-Wellenlänge hörte. . . with gute Aufnahme. Leider muß ich die kleinen Zangen benutzen, um die Welle des waveband zu verschieben.
Danke wieder für das Maß der zerbrochenen Welle außerhalb des Chassis. Wenn Sie nicht imstande sind, eine gute benutzte wellenschalter Welle zu lokalisieren, dann möglicherweise kann sie repariert werden oder sogar verstärkt werden.
Mit freundlichen Grüßen,
Robert
Greetings and many thanks Jens,
I have translated and read all of your reply. The Graetz production history is very interesting, and I am very happy to own the beautiful model. The circuits are almost identical to those which are found in the SABA 455WK model from 1938, and it also has the "art deco" dial glass.
I shall place a copy of this information into the data brochure which I prepare for every radio which I restore.
From the visual appearance of my 51W version and the details you describe, I can understand that some limited production of models would appear as soon as possible after the production of armament items were completed.
I have noticed the several different part numbers on the dial glasses depicted in the model data photos. On my receiver the Normal power and then Economy is still operating according to the schematic - with the Sparungschalter providing either 198 volts or 354 volts.
The receiver presently functions well on the KWII band, and last night I was listening to the English news transmissions from  Radio Ukraine International and from Romania within the 41 and 59 meter wavelength . . . .with good reception. Unfortunately, I must use the small pliers to move the shaft of the waveband.
Thank you again for the dimension of the fractured shaft outside the chassis. If you are unable to locate a good used wellenschalter shaft, then perhaps it may be repaired or even strengthened.
With friendly greetings,
Robert
