grundig: 210; Satellit Functional Block Diagram
09.Oct.08 19:46
5437
Alessandro Capitani (I)
Articles: 5
Count of Thanks: 17
Alessandro Capitani
 Hi!
For all Satellit enthusiasts I have published a simplified block diagram that I hope will help on reading/interpret the original schematic diagram.
It has not been a simple job since the 210 is indeed quite complex, but at end I accomplished what I had in mind.
I have tried to keep the position in the functional diagram as close as possible similar with respect to the original schematic. This should also help you on cross-checking the two documents.
As all things produced in spare time, it is possible the document is not 100% accurate, in that case I will appreciate your feedback and comments to improve it.
You can find the document in the schematic section of the Grundig Satellit 210, file name is:
d_grundig_satellit210_block2_1.pdf
Alessandro.
for your convenience, I've included a direct dowload link. Enjoy.
