grundig: 4006U; Grundig Majestic
? grundig: 4006U; Grundig Majestic
04.Dec.10 11:57
110
John Kennedy (USA)
Count of Thanks: 18
I have aquired a 4006u. It is a beautiful radio but has some problems, The back and the power cord are missing. Of greater concern the power screw seems to be missing, This is all guess work on my part. There are two tapped holes under the fuse that are marked 110 and 220. In pictures of similar units I can see that there is a plastic capped screw in the 110 hole. I see the connection on the schematic and can see that it does connect either the 110 or the 220. My question is does anyone know about how long the screw is? I don't want to go too long and screw into some vital part and ruin it or too short and not make connection. I am assuming that I can use a regular screw here and that the specific screw is not available. If anyone knows of a source for the plastic capped screw that belongs here i'd be glad to hear of it. I have discovered that the fuse has been covered with aluminum foil so I am currently assuming there are power problems to be fixed once I can connect the power.
Thanks in advance for any help or suggestions you may have.
John
voltage screw
08.Dec.10 22:11
110 de 2708
Leo Van Houten † 2013 (USA)
Articles: 13
Count of Thanks: 10
John, I can help you with the voltage screw. Contact me. Leo
