grundig: Grundig 5010 dial removal
? grundig: Grundig 5010 dial removal
30.Nov.24 11:28
23
Kevin Richardson (AUS)
Articles: 8
Count of Thanks: 2
I'm trying to remove the dial glass from my Grundig 5010. I have removed the spring clips from the end but the glass seems to be stuck to the chassis with double sided tape. It is really stuck on and I'm concerned I may break the glass if I put too much pressure on it.
is there a trick to make the dial removal easier?
30.Nov.24 13:10
23 from 387
Rolf Beckers (D)
Articles: 218
Count of Thanks: 3
Rolf Beckers
There are rubber strips between the scale and the chassis. Over the years, the rubber rots into a sticky mass so that the scale sticks. You have to be very careful to remove the scale without force or tools.
