Grundig C4100 Tape, Radio issues
? Grundig C4100 Tape, Radio issues
28.Aug.20 08:25
77
Uday Kalburgi (IND)
Articles: 109
Count of Thanks: 5
Uday Kalburgi
Hi,
Greetings from Bangalore, India.
I am trying to restore solid state Grundig C4100 Tape/Radio. The power section looks to be out. Nothing is happening on any front. mains to Battery switch is also faulty, loks like capacitors are to be replaced.
To access the capacitors, I have to remove dial plate and all the holding plastic pins are brittle. the tuning capacitor wheel is also broken and earlier someone has repaired it.
Need advise, should I leave it as it is or taking out everything, breaking the plastic, look, tuning wheel repair, will become repair , which I hate to do. These parts are available any where?
Looking for advise
Warm Regards
Uday K
29.Aug.20 14:08
77 from 1473
Marc Gianella (CH)
Articles: 302
Count of Thanks: 6
Dear Mr. Kalburgi
I can't give you an advice because I don't know the value of such a radio in India.
As I own such a model in a relatively bad state but complete, I can offer you the replacement parts you will need.
With my radio, the mains and the audio amplifier seem to be working. The radio doesn't, perhaps because the switches are corroded. Only part missing is the outermost segment of the telescopic antenna.
I'd give you the whole radio for free, but the postage to India is way too much. Sending some parts up to a total weight of 500g is reasonable.
So the mentioned Plug, the mains/battery switch, the tuning cap wheel, every mechanical part you might need is here in functional state.
Please let me know if and what parts you need.
Kind regards and greatings from Switzerland
Marc
30.Aug.20 14:12
134 from 1473
Uday Kalburgi (IND)
Articles: 109
Count of Thanks: 4
Uday Kalburgi
Good Eveing Marc,
So nice of you !! Thank you so much !!.
Giving is something very noble action.  I sincerely appriciate your help.
I would like to pickup whole set and will pay postage and any other additional expenses.
We have to wait till air cargo/post  to start. My Austrilian Post is also stuck !!. Hopefully Covid goes off soon.
I will be in touch with you Sir !!
Warm Regards
Uday K
