grundig: Grundig 'RTV 320U' loudspeakers ('Box 8' or 'Box 412'?)
? grundig: Grundig 'RTV 320U' loudspeakers ('Box 8' or 'Box 412'?)
19.Sep.12 15:18
Jeff Miller (USA)
Articles: 71
Count of Thanks: 30
Jeff Miller
Hello,
What was the correct (original) loudspeaker for the 1969 solid state Grundig "RTV 320U"? Was it the "Box 8" (shorter) or the "Box 412" (taller)? Maybe the customer could make a decision depending on available space, etc.?
Thank you,
Jeff
This thread was moved automatically.
This question was moved automatically to the board "Talk" to get more possibilities for answers.
Moved from board »RADIO MODELS DISPLAYED« on 25.Sep.12 15:18 from automatically
different options
25.Nov.12 12:15
111 de 4080
Mark Hippenstiel (D)
Articles: 1192
Count of Thanks: 11
Mark Hippenstiel
Jeff,
although I have seen the RTV320U mostly in combination with Box 8, you could of course choose your own.
The German brochure of 1968 shows a matrix of possible speakers (see below). While this doesn't cover the RTV320U specifically, the KS742 has a similar chassis/amp combination.
Hope that helps,
Mark
"besonders geeignet": speakers are 'speficially suited' for use with the model
"verwendbar": can be used with the model
Moved from board »* TALK - visible for members only« on 25.Nov.12 12:31 from Mark Hippenstiel
