grundig: HVS1; Raumhall-Einrichtung
Can the HVS-1 module be attached to my model 5490ST/U and function also with the Stereo-Decoder 5U? On the front panel, is the small selector lever which is located by the ECHO position??
MfG,
Robert
HVS use where?
how are you?
Yes thats right, you can use the HVS1 together with Stereo Decoder 5U
on your 5490 St/U
If you need more Infos, please post here.
Best regards from
HANS
HVS
Thank you so much. I did not know if the reverberation effect would NOT be so good if used while FM band is engaged - or does the effect only function while in PU (tonearm TA) or TR (tape player TB) modes.
I will look more closely at my schematic to evaluate/confirm circuitry!
In a Grundig Technische Informationen sheet I see block diagram with NF1, and HV1, with HS1 but I do not see Stereo-Decoder 5. I should be looking at different information??
Mfg,
Robert
ECHO on FM?
Hello Robert,
Ind.1 Oh I see, your questions first was: is the HVS1 in action on FM -Stereo?
Ind. 2 Next, is this good or use full to do this?
Ind.1 yes they is busy also on FM- Stereo.
See here and attachment.
green lefthand cannel, red righthand cannel
ECHO is: left AND right (Mono) after HSV1 is mixed to left- and right-hand cannel.
ECHO are not recordet to Tape
Ind.2 For example, you make an recording from a FM Broadcasting. If you play this, it is your decision to use ECHO or not. The same is, when you listen at the same time to this Broadcasting . ECHO yes or no?
O.K. ? Recommended from me is, use a low Value of ECHO! Maybe you have the indention from HOFBRAEUHAUS.
I think this is all for the moment.
Best Regards Hans
- 5490U/ST Hall (385 KB)
Too Much Time at Hofbrauhaus!!
Your wisdom extends far beyond the radio world. . . .As Flying Lieutenant, I was too many nights at the Music Halls and Liquid Refreshment centers near Frankfurt or Ramstein. To this date, I am unable to resist the Wienstephaner.
I understand now that the ECHO is active at all times it is connected, and control is from "minimum delay" to "maximum delay"?
The HSV1 is not so common, but I wished to confirm its applicability before I buy and install one. . . . they are not so common, I believe.
MfG,
Robert
Finaly
Prosit! I am glad.
Regards from good old Germany
Hans
