Heathkit SB102
Heathkit SB102
05.May.06 14:00
Mietek Jozwik (PL)
Articles: 14
Count of Thanks: 28
I am looking for any experience in replacing original transmiter output tubes 6146 by the other tube model.
05.May.06 14:35
Michael Schlör † 30.10.22 (D)
Articles: 80
Count of Thanks: 15
Hello Mietek,
over the decades I used several pairs of the 6146 family, such as 6146A, 6146B and the rugged 6146W. You only have to re-neutralize the PA. Don't mix different tube models, always use a pair of the same tube type. Depending your power-supply, I would prefer the -B or -W tubes. Those can work better with Ua over 850V DC. There is a difference in Plate Dissipation: the 6146, 6146A and 6146W 25W, the 6146B 35W
73,
Michael Schlör
DJ8IJ
08.May.06 10:42
Mietek Jozwik (PL)
Articles: 14
Count of Thanks: 19
Hi, thanks for answer.
The problem with that tube is they are practically not available in Poland. So I am looking for replacemnt. Some TV's sweep tubes looks similar in catalogs but dummy replacement can fire out nice old piece of equipment.
Vy, 73
Mietek
sp5hbt
08.May.06 16:05
Articles: 80
Count of Thanks: 22
Hello again,
DO NOT use any TV sweep tubes!! This will damage your SB102!! If they look similar to the 6146's, for shure: they are NOT the same. The tube data will be completely different! It's very difficult to redesign the PA-tube configuration for a sweep tube as well as the Pi-network!
The only replacement-tubes you can use are:
8298A or QE05/40 or YL1370.
These tubes can be used by only neutralizing the PA.
73,
Michael Schlör
DJ8IJ
