hismasters: HMV1121:scales
02.Jul.12 17:32
2246
Michael Watterson (IRL)
Articles: 1126
Count of Thanks: 15
Each scale glass is 290.5mm long and 38mm wide. About 4mm thick.
On the 300dpi scan uploaded the "graduated" part of the MW scale is 225.5mm long. There  is a 600dpi scan, but too large to upload!
Clear Laser Decal paper will give black water-slide transfers of the text. To achieve "white" either use a "White" cartridge in an Alps printer, or with suitable laser/copier toner a White (or metallic) thermal transfer sheet can be passed on the Decal print out through a laminator and peeled off to leave white on the black (remelted) toner.
Not all toners work.
