Hong Kong (HK)
This article refers to the country: To the country
Hong Kong (HK)
23.Aug.13 16:25
25
Roy Varley (AUS)
Count of Thanks: 25
We now have two manufacturer entries for Shiba Electronics Ltd:
One as "Panashiba" the other as "Shiba Electronics Ltd (Panashiba)".
I think the entry "Shiba Electronics Ltd (Panashiba)" is correct in that the company still exists with that name and Panashiba is still a brand name. The 4 models listed under "Panashiba" should probably be relisted under "Shiba Electronics Ltd". What do you folks think?
-Roy
Un-intended consequences.
23.Aug.13 18:53
25 de 6046
Michael Watterson (IRL)
Articles: 1126
Count of Thanks: 22
Yes, you are right.
Of course I searched for Shiba Hong Kong, found nothing and then started to create it. So then I researched and found out much more about Shiba (I suspect they source stuff made by others and then  get it rebranded for other companies, if so there will be little with their own name on it.).
I didn't think to search for the other companies or the Brand. Sorry.
We should probably move them all to the new entry and "delete" Panashiba. But I'm not sure, no doubt the Maker Admins will know what should be done.
Panashiba / Shiba
23.Aug.13 19:12
30 de 6046
Mark Hippenstiel (D)
Articles: 1192
Count of Thanks: 19
Mark Hippenstiel
Gentlemen,
the older entry takes precendece. I will update the manufacturer entries accordingly. Thank you for pointing this out.
Regards
Mark
