tefag: How do you adjust voltage selector
? tefag: How do you adjust voltage selector
13.Aug.23 23:49
72
Donald Cochrane (USA)
Articles: 85
Count of Thanks: 7
I don't want to break anything but I cannot figure out how to change the voltage selector from 220 to 125v.
Thank you,
Donald
14.Aug.23 15:35
72 from 922
Robert Latzel (D)
Articles: 319
Count of Thanks: 5
Robert Latzel
Hello,
I would proceed as with radios with a similar voltage-selector:
Loosen the central screw on the voltage selector.
Then detach the black back bakelite plate.
Then rotate it.
The horizontal display in the back is telling the selected voltage.
Reinstall the screw.
Good luck!
Robert
14.Aug.23 19:24
100 from 922
Articles: 85
Count of Thanks: 4
Thank you for your reply.  The wire atatched to the dial was stiff but I was able to turn the dial carefully.
Donald
