hewlett-pa: HP 8558B Horizontal Sweep
? hewlett-pa: HP 8558B Horizontal Sweep
![Hernani Capela](https://www.radiomuseum.org/image.cfm?image=hernanirmog.jpg&width=120&height=140)
My HP 8558B/182T lost horizontal sweep, using the external sweep works, but not synchronously, of course.
I ask the experts acquainted with HP equipment, the horizontal sweep is generated internally on the HP 182T or comes from the 8558B module, which I think is the case, and then I'm afraid to re-stir this technology monster.
PS: I accept PDf's or buy original paper manuals on HP182T.
Best Regards
H Capela
Count of Thanks: 7
![Hans Werner Stanzel](https://www.radiomuseum.org/image.cfm?image=hans_werner_stanzel_2017.jpg&width=120&height=140)
Hello,
the sweep is generated on A8 bord inside the 8558. Repair without
having extenders (see manual) is nearly impossible, but check for
shorted Tantals first.
Regards Werner
Hi Werner,
I do not have extenders, yes I will check all the capacitors of the A8 module first.
In times I tried to get an extender or make one for 8558B, but as it was not accessible, and as I didn't need it much, I didn't go ahead with the project.
Thankful for your information.
Best Regards
H Capela
Hi Hans Werner,
I am working on the case again , what i found was the fingers of the switches loose , nothing new , i have already gone through that and used aralditte to fix them ,but it does not work for a long time, I am using mechanical fixation , I hope to reassemble everything in the first form correctly, once the first time...
Best Regards
HC
Attachments:To thank the Author because you find the post helpful or well done.
