sony: ICF-SW55: A common failure and a not so easy fix
26.Oct.23 16:53
77
Jose Mesquita (P)
Articles: 111
Count of Thanks: 19
Jose Mesquita
Got this radio as not working. Symptom is the CAL message at power ON not being cleared and the radio turns off.
This CAL issue is one of the common failures found in this model. After reading the SONY documentation and several Internet shared information on this issue, namely from Fabio from Antica Radio, I had some insight on the subject.
The user guide mentions that  "CAL appears when power is supplied, or when calibration adjustment is made". When inserting new batteries, the CAL msg displays for a couple of seconds. The radio will complete the CAL procedure and enters normal operation defaulting to 150 kHz.
The CAL function can also be called manually by pressing AM Function and then Memory 1.
Another one even more common failure relates to defective electrolytic capacitors that results in several symptoms like strange audio noises or no sound at all.
The electrolytic capacitors tend to leak the electrolytes that spread over the other PCB components, resulting in all sort of problems. By removing the failed capacitors, cleaning both sides of the PCB with isopropyl alcohol, and installing new capacitors of the same type, will usually fix these issues. Some prefer to replace the old electrolytic capacitors with tantalum ones. I prefer to install the same type from modern, fresh batches.
After opening my radio, I immediately noticed two things.
Someone has been inside before, and had replaced all electrolytic capacitors by tantalum equivalents. The job looked nice with clean solder joints. All of them? Well, not exactly. One cap (C236) in the DC-DC converter, hidden inside the metal shield, was forgoten.
The other thing was a burnt transistor (Q53) acting as a 6V switch to the audio power amp (IC7).
So I didn't think too much about it, just replaced the burt transistor (Q53) with a SS8550-SMD that is close in specs to the original. Applying 6V DC from my power supply gave me a few amps of current peak and burning smell. Nice.
I removed Q53 again, and applied power to see if the radio would pass the CAL phase. No luck, as the radio keeps powering off after a few seconds after CAL message.
So I had two different issues, one for CAL and another for the audio stage.It turned out that both issues were related.
The IC 7 audio IC didn't look in short at pin 12 and GND. Something else was causing the short on the B+ line. It must be the 470uF bypass capacitor C195. Then I realized that that nice replacement of the defective electrolytic capacitors by tantalum ones had gone wrong. All tantalum caps were installed with reverse polarity!
I removed the tantalum caps and threw them away, as they were all more or less damaged by applying reverse polarity voltage.While doing so, a terrible smell of burn electrolytes told me that the PCB was not properly cleaned when replacing the original caps with these tantalums. So I used IPA to have a brief cleaning of the PCB, before installing new fresh batch electrolytic caps.
That fixed the audio issue but the CAL message issue kept popping up. Using an oscilloscope to check the signal at pin 6 of the PLL (IC8) told me that there was no oscillation at all.
This time I knew the cause. Just above this IC8 is another infamous electrolytic cap that surely had leaked around and contaminated the trimmer cap (CT6). By removing CT6 and measuring it for DC resistance, I got around 300KR to 3MR depending on the position of the rotor.
Powering up the radio I finally saw the CAL(ibrating) message completing and the radio displayed the 150kHz RF band with normal RF noise.
Replaced TC6 with a similar 10pF trimmer. Could not adjust the osc frequency to the specified 6.275MHz as my current oscilloscope use just two decimal places giving me alternating values between 6.27 and 6.28MHz.
Took the opportunity to replace the MCU 0.22F/5.5V supercap (C903) as these things tend to deteriorate as well.
I am enjoying my classic Sony radio while writing these lines.
Hidden cap inside the metal shield of the DC-DC converter.
Burnt transistor switch for audio power amp.
Defective components. Supercap was weak. Tantalum caps and transistor were victim of wrong install.  Trimmer cap was a genuine victim of the original issue of leaking electrolytic caps.
27.Oct.23 10:48
77 from 4467
Torbjörn Forsman (S)
Articles: 188
Count of Thanks: 7
Back in the 90's, it was not uncommon with SMD tantalum capacitors installed with wrong polarity as some, particularly japanese manufacturers used to have the polarity mark at the negative end while for example Kemet had the mark at the positive end.
I once (maybe around 1996-97) encountered a batch of PCBs where there were a few SMD tantalums in a telephone line interface. All of them were installed backwards by the contract manufacturer. It turned out that the circuitry worked for 10-15 minutes after first power up, but then the leakage current of the tantalums increased too much. So the PCBs could pass the final test at the manufacturer before they failed.
27.Oct.23 16:10
109 from 4467
Jose Mesquita (P)
Articles: 111
Count of Thanks: 3
Jose Mesquita
Thank you for your information, Mr. Torbjörn.
I have that dilemma with SMD tantalum capacitors polarity markings as well. The pass through radial tantalum capacitors usually do not have this ambiguity as we can see the (+) mark at one of the legs.
I bought my radio from a local seller in Lisbon on OLX; he told me that he bought it from eBay Italy as used and in good working worder.
My seller told me that he was not able to pass the CAL phase on arrival, and have enquired the Italian seller that insisted the radio was OK. So he decided to keep the radio and just put it on sell locally as a defective unit.
What you have described concerning the tantalum capacitors behavior when subjected to reverse polarity would explain why the Italian seller insisted that the radio was working before shipping.
27.Oct.23 21:22
139 from 4467
Michael Watterson (IRL)
Articles: 1108
Count of Thanks: 5
I encountered a batch of new bead capacitors that would explode when fitted. Testing before install revealed the white print with + and value was on the wrong side. We binned them all.
