INCAR model identification help
? INCAR model identification help
Hello,
I own the attached INCAR radio. Can somebody help me identify the model and the corresponding schematic? I couldn't find it on the INCAR page, or maybe the model is already there without a picture.
I would like to restore it.
Full resolution pics are here.
Thanks & regards
Davide
Hello Davide,
I can already tell you that this is a "German model" made by Tonfunk. Tonfunk has made radios for many third parties so it's per se nothing too much out of the ordinary.
That also means that is are a plethora of variants - this is even the case for their standard production. Therefore it would be needed for you to specify the tube complement of your radio.
The chassis are very similar across models. Have a look at Tonfunk W191M for instance (we have images only for the EL41 version, but the model also exists with EL84).
Regards
Mark
Edit: of course this is just an example of one Tonfunk model with a similar chassis, but it's not fitting very closely overall.
Hello Davide,
I think you can work with the schematic of WM191M except for the magic eye. I don't think that the two thick resistors to the right of the output transformer are original (green, probably with asbestos - and grey, probably a wire resistor).
Good luck,
Mark
Many thanks Mark.
Of course I'm not an expert, what do you exactly mean by "specifying the tube compartment"? Try to retrieve the installed valves' manufacturers/brands?
At the same link I added some photos after some cleaning.
Thanks
Davide
Tubes = Valves.
The glass things with pins at the base. I can see one is probably an EABC80.
Davide,
The tube complement is indeed the line-up of tubes, or their types, as the manufacturer is not important. This would just have helped with identification.
The chassis is a 191... series and should be almost identical to the one I linked. It has a fairly standard set of tubes: EC92 (FM tuner looks like a Miniature type), ECH81, EF85 (maybe EF89), EABC80, EL41 and in your case EM80 as magic eye. The set uses a dry rectifier.
Regarding the identification: I have a very low resolution folder that shows a very similar radio VZ603 of which we have two versions: VZ603/3D and VZ603RF/3D - both should have 3 speakers and the latter is a phono combination. They don't fit.
There is however also a VZ603 schematic with only one speaker, and EC92, EF85 and EM80. That seems to be a match, with some incertainty. What I said previously about the added resistors turns out to be a factory-added resistance for the 270 V tap of the transformer.
I think you can create the model with that type, and we'll add a note that the identification is not 100% certain.
Kind regards
Mark
