Infos zur Type AC064 (AC064)
31.May.13 17:26
2381
Gerhard Eisenbarth (D)
Articles: 99
Count of Thanks: 19
Bericht in der Wireless World vom 17. Sept. 1930 als Nachlese zur „National Radio Exhibition – Olympia 1930“ zu neuen Röhren.
Auszug u.a. über die Type AC.064
“Valve Improvements
On the Mullard stand, we shall see a series of new A.C. power output valves with directly heated filaments consuming 1 ampere at 4 volts. Not only does the indirect cathode type of construction  not lend itself particularly well to large output valves, but also the absence of a separate heater helps in making the provision of automatic bias a much simpler problem. These considerations have led the Mullard Company to market the AC.104, AC.064, and AC.044, who’s A.C. Resistances range from 1,150 to 2,850 ohms. The maximum anode voltage is 200, and a glance at the characteristics suggests undistorted outputs in the order of 1 watt. Hum will not be introduced, first due to the thick filament and secondly, owing to the absence of subsequent amplification.”
