klein: FS5B; Fernseh-Service-Sender
This article refers to the model: Teletest Fernseh-Service-Sender FS5B (Klein & Hummel; Stuttgart-Kemnat (Marke: K+H, Telewatt, Schwabenradio))
06.Jan.04 21:02
1865
The FS5B (B = "for Belgium") set contains in total 12 tubes: EZ81, 150C2, six ECC81, two ECC82 and two ECH 81.
Power supply is 240V, 220V, 125V or 110V
The dimensions are
- width: 395 mm
- height: 240 mm
- depth: 220 mm
Serial number of my set is 10-1490
It has a big rotary switch for selecting the 11 TV channels, plus a 12th channel, that seems to be a special one.(FM range?)
Also image 3 IF ranges:
- from 16 to 21 MHz
- from 21 to 29 MHz
- from 29 to 45 MHz
and a 5.5 MHz range, FM modulated, from 5.2 to 7.2 MHz, als probably as harmonics fram 10.4 till 14 MHz, which is the FM IF range.
